pi-top [4] DIY Specification
Full technical specification of the pi-top [4] DIY
PT4SPECS
Screenshot 2019-12-10 at 18.17.27
Requires Raspberry Pi 4 - not included with pi-top [4] DIY
pi-top [4] Cooling
Item
Specification
Heat Sink
Aluminium finned heat sink for Raspberry Pi SoC
Fan
Integrated 0.9 Watt centrifugal cooling fan (30 x 30 x 7 mm)
Air flow rate: 1.5 CFM
Static pressure: 92 Pa
Raspberry Pi CPU temperature at 100% 4-core CPU load:
Inside pi-top [4]: 64 °C Standalone RPi: 85 °C with thermal throttling of CPU due to max temperature of Pi being 85 °C
pi-top [4] Battery and Power
Item
Specification
Charge Time
1 hour 15 minutes from 0% to 100%
Discharge Time
5 hours as standalone pi-top [4]
2.5 hours with screen/keyboard attached
Battery Type
Built-in 19.24 Watt-hour (7.4 V, 2600 mAh) Lithium Polymer Battery
Voltage
Min = 6 V, Nominal = 7.4 V, Max = 8.4 V
Power Supply
36 Watt, 12 V @ 3 A
pi-top [4] connectors
Label
Item
Specification
2
USB C power Jack
USB Type C Power Jack. 12V @ 3A or 15V @ 3A
3
pi-top Display Port
Proprietary Port. Supplies HDMI and 5V for pi-top[4] screen
4
Micro HDMI Port
Micro HDMI Port
6
USB
2 x USB 3.0
7
CSI ribbon slot
Slot for CSI ribbon to be fed through
14 + 16
Air Channel
Air Channel to supply cooling fan
18
Micro SD Card Slot
Externally-accessible micro SD card slot for RasPi.
20
pi-top Maker Architecture Connector
Single Connector carrying Raspberry Pi GPIOs, USB 2.0, Power and DSI for interfacing to all peripherals and the pi-top Maker Architecture.
Includes pi-top [4] back power capability
21
Pogo Interface
8 pins with 5 V, UART, and I2C. Can also identify the plate connected.
pi-top [4] Speaker
Label
Item
Specification
15
Internal Speaker
1 W Nominal (2 W max), mono speaker
pi-top [4] User Interface
Label
Item
Specification
12
Programmable Buttons
4 x Buttons, also available on system standby
11
Mini Display
OLED Monochrome Screen, 128x64 pixels. Available on system standby
1
Power Switch
Momentary Toggle switch. Used to power on/off and restart device
17
Status LEDs
Raspberry Pi Power LED (Red) + SD Card Activity (Green)
13
Docking Clasp
Releases the pi-top [4] from docks and plates
19
Underside Label
Product Serial Number. Information for support.
Power requirements
The pi-top [4] is the first of our products to use USB-C Power Delivery. This means that it is compatible with a wider variety of chargers than our previous products. The important thing to note is that the pi-top [4] will only accept a 12Volt or a 15 Volt power supply.
If you're not sure if your charger can do this, then have a look at the writing on the body of the charger. You should be able to see 12V or 15V on the body.
We always recommend using a charger with a minimum of 36 Watts so that you charge the battery fastest and provide power to any of the additional plates
15
Alternatively, if you're looking to buy a new charger, then the product description will tell you as well.
