FHD Touchscreen & Bluetooth Keyboard Technical Specifications
Touchscreen
Item
Specification
Size
11.6” diagonal
Resolution
1920 (H) × 1080 (V)
(FHD, 1080p)
Interface
Connection methods using the pi-top Display Port:
  1. Use the pi-top Display Cable to the pi-top [4]
  2. Use the pi-top Touchscreen Dongle to connect to other devices (such as a Raspberry Pi)
    1. Touchscreen dongle breaks out pi-top Display Cable interface into:
      1. Standard HDMI
      2. Standard USB-C for power
      3. Standard micro USB for Keyboard and Touch functions
      4. Standard USB-A for powering a 5 V device (such as a Raspberry Pi)
Keyboard Connect Dock to connect a pi-top keyboard via USB
Up to 10 point touch input
Refresh Rate
60 Hz
Response Time
25 ms
Type
IPS
Colour
16.7M, 24-bit
Viewing Angle
≥80° all directions
USB-C Power Requirements
Standard USB-C 5V/3A specification
Power Rating
8W Max including keyboard charging
Bluetooth Keyboard
Item
Specification
Connectivity
Keyboard Connect Dock (USB + Charging)
Bluetooth 3.0 - auto-pairing to connected pi-top [4]
Micro USB port (USB + Charging)
Layout Options
US
Battery
3.7 V, 740 mWh (210 mAh)
Charge time: 1 hour
Use time: 36 hours (constant use, Bluetooth mode)
Power Switch
Momentary Toggle switch
Auto on and auto-sleep mode
Keyboard LED Status
LEDs
ON
OFF
FLASH 1 Hz
FLASH 3 Hz
Red power LED
The keyboard isn't connected to a USB host
AND the battery level is lower than 20%
Keyboard off
Green power LED
The keyboard is connected to a USB host
OR the battery level is higher than 20%
Keyboard off
Bluetooth LED
The keyboard is in paired and in Bluetooth mode
Keyboard off
OR Keyboard is connected to a USB host and there is no Bluetooth pairing action
Keyboard Bluetooth is trying to reconnect to the Bluetooth master
Keyboard Bluetooth is in pairin
