What does pi-topOS do differently to Raspbian?
pi-topOS builds on Raspbian, so a lot of things are identical. However there are some differences.
pi-topOS changes some of the theming provided by Raspbian, and adds out-of-the-box device support for pi-top hardware.
The focus of development in pi-topOS is primarily around device support for pi-top hardware, and usability improvements. Raspbian handles much of the backbone functionality that pi-topOS depends on - things like the way that software stays up-to-date, the general desktop environment, etc.
This means that pi-top developers are not directly involved in the development of these core features, even though pi-topOS directly benefits from this work done by the Raspberry Pi Foundation.
What are the main things that are different in pi-topOS?
We install multiple extra bits of software (known as packages) on top of Raspbian. These packages are responsible for such things as:
  • plug-and-play functionality with pi-top hardware
  • modifying the user interface
  • notification system
  • automatic software updater
  • onboarding/tour
  • additional settings for pi-top hardware
  • about page to show key information about the OS that is installed
These are installed by a “parent” package: pt-os.
Other changes, performed during the creation of the OS, include:
  • Changing the default pi user password
  • Enabling VNC Server by default
  • Adding pi-top software repository
  • Installing pi-top software (via pt-os package)
  • Modifying SSH text interface
  • Changing /boot/config.txt
    • Force HDMI out of HDMI1 on Raspberry Pi 4 to allow for VNC without a connected display
      • hdmi_force_hotplug:1=1
      • hdmi_blanking=1
    • Enable SPI0 to detect possible original pi-top/pi-topCEED
      • dtparam=spi=on
    • Enable SPI1 to use pi-top [4] OLED - default on
      • dtoverlay=spi1-1cs
      • Enable I2C to communicate with all pi-top hardware
        • dtparam=i2c_arm=on
        • Enable extra video codecs in Raspberry Pi GPU firmware; adds native support for Raspberry Pi Camera
          • start_x=1
        • Set GPU memory allocation to 128MB
          • gpu_mem=128
        • Configuring DHCP server on pi-top [4]’s USB-OTG port
        • Setting up screen blanking
        • Setting up dynamic swap for better performance
        • Changing hostname from “raspberrypi” to “pi-top”
        • Setting default locale and keyboard layout to US
        • Modifying system logging settings to persist (to aid with debugging)
        • Add build information into /etc/pt-issue
        • Clean up unwanted leftover directories and packages from Raspbian
