pi-top [1] + pi-topCEED Hub fix
There's a new kernel update for the RasPi. It interrupts the communication between the hub and the RasPi
This article is for pi-top [1] and pi-topCEED users whose pi-top Hub is no longer communicating with the Raspberry Pi. This article is for you if you're having the following symptoms:
  • You can't see the battery icon
  • You shutdown your pi-top and the red light on the Raspberry Pi stays on
  • If you have a pi-top [1] then you can't see the battery icon.
Click on the link below to download the file. To install it on your pi-top [1] or pi-topCEED, simply download the file to the pi-top and double click to run. Follow the steps in the installation and reboot at the end! The entire fix takes less than 3 minutes.
Download the file from the link below
pi-top hub - Mk1 OS Fix
