pi-topCEED
The maker's Desktop! Technical Specifications on the pi-topCEED
The pi-topCEED was our second product and our first desktop. We understand that many of you are still using it these days. So here's all the information you'd need to get up and go!
Just like the original pi-top, the pi-topCEED Hub communicates with the Raspberry Pi via SPI and does this on SPI Port 0. This means that you should try and stay away from using GPIOs 9, 10, and 11. If you do try and use these for any lessons then you may find some issues and you'll be forced to reset your OS or reflash your SD Card. Head over to this section if you're unsure how to do that.
Technical Specification of pi-topCEED
Item
Specification
Resolution
Full HD (1920x1080) LCD Screen
Screen Size
14’’
Colour
6-bit colour (262k)
Power Supply
18VDC @ 3.0A (Max)
Add-on Rail
Add-on Rail for pi-top Accessories. Used for adding a PROTO board, Speaker or PROTO+.
