pi-topCEED Screen Issues
Having issues with the screen? Here's a few things to try
  • Make sure the micro SD Card has the correct OS that you would like to use.
  • Check that the Raspberry Pi itself is working. It’s best to try this with another HDMI display. This way the image on the SD Card can also be tested
  • The HDMI cable between the pi-topHUB and Raspberry Pi may also be loose. Ensure that the cable is inserted all the way into each HDMI port.
  • Check your assembly. The screen cable from the LCD can only go into the hub in one direction, though with some force it can go in upside down
