USB ports
Connect your USB keyboard, mouse or a portable storage device into the pi-top USB 2.0 ports.
  • You can access your USB folder via the file manager icon on the taskbar or in the main menu within Accessories.
  • Your device can be found within "Media"  where you can access the folder to your USB drive.
  • The USB port on the Hub has the same rating of regular USB2.0 which is 5V x 0.5A = 2.5Watts.
