Getting started with the pi-top[4]
If you've just opened up your pi-top [4] this is the place for you
The best place to start is our getting started guide on our learning platform called Further.
If you would like help with your onboarding and implementation, please schedule an online meeting with us.
Further
Further also contains lots of lessons and guides on how to use all the robotics and electronics components.
SD Card with pi-top OS
Your pi-top has an SD card where its software is stored. If your pi-top is older than a year or two, it likely requires reinstalling the SD card, following this guide.
Display
The pi-top was designed to work as a standalone device for robotics and similar projects. However, it is possible to use it with a standard computer screen and keyboard, see this guide.
